ISCW LAB: MPLS VPN ROUTING VRF
Qui hoạch IP:
(1)192.168.1.0/24
(2)192.168.2.0/24
(3)192.168.3.0/24
(4)192.168.4.0/24
(5)192.168.5.0/24
(6)192.168.6.0/24
(7)Lo0: 10.10.10.10/24
(8)Lo0: 20.20.20.20/24
(9)Lo0: 1.1.1.1/24
(10)Lo0: 3.3.3.3/24
(11)Lo0: 2.2.2.2/24
(12)Lo0: 30.30.30.30/24
(13)Lo0: 40.40.40.40/24
1.Yêu cầu:
·Cấu hình MPLS domain giữa PE01 – P – PE02 (IGP = RIPv2)
·Cấu hình BGP AS 1 giữa PE01 và PE 02
·Trên PE01 tạo vrf A1 và B1 tương ứng với mỗi Router A1,B1
·Trên PE02 tạo vrf A2 và B2 tương ứng với mỗi Router A2,B2
·A1 – A2 – B1 – B2 chạy giao thức định tuyến EIGRP
i.A1 : AS = 10
ii.A2 : AS = 30
iii.B1 : AS = 20
iv.B2 : AS = 40
2.Cấu hình:
ROUTER A1:
hostname A1
no ip domain lookup
interface Loopback0
ip address 10.10.10.10 255.255.255.0
interface FastEthernet0/0
router eigrp 10
network 10.0.0.0
network 192.168.1.0
no auto-summary
ip classless
ip http server
End
ROUTER B1:
hostname B1
ip cef
no ip domain lookup
interface Loopback0
ip address 20.20.20.20 255.255.255.0
interface Serial0/0
clock rate 2000000
interface FastEthernet0/1
ip address 100.100.100.100 255.255.255.0
no keepalive
router eigrp 20
network 20.0.0.0
network 100.0.0.0
network 192.168.2.0
no auto-summary
ip classless
ip http server
End
ROUTER PE01:
hostname PE01
no ip domain lookup
ip vrf A1
rd 1:100
route-target export 1:100
route-target import 1:100
ip vrf B1
rd 1:200
route-target export 1:200
route-target import 1:200
interface Loopback0
ip address 1.1.1.1 255.255.255.0
ip vrf forwarding A1
interface Serial0/0
ip vrf forwarding B1
clock rate 64000
mpls label protocol ldp
tag-switching ip
router eigrp 100
auto-summary
address-family ipv4 vrf B1
network 192.168.2.0
no auto-summary
autonomous-system 20
exit-address-family
address-family ipv4 vrf A1
network 192.168.1.0
no auto-summary
autonomous-system 10
exit-address-family
router rip
version 2
network 1.0.0.0
network 192.168.3.0
no auto-summary
router bgp 1
no synchronization
bgp log-neighbor-changes
neighbor 2.2.2.2 remote-as 1
neighbor 2.2.2.2 update-source Loopback0
no auto-summary
address-family vpnv4
neighbor 2.2.2.2 activate
neighbor 2.2.2.2 send-community extended
exit-address-family
redistribute eigrp 20
no auto-summary
no synchronization
exit-address-family
redistribute eigrp 10
no auto-summary
no synchronization
exit-address-family
ip classless
ip http server
no ip http secure-server
End
ROUTER P:
hostname P
ip cef
interface Loopback0
ip address 3.3.3.3 255.255.255.0
ip address 192.168.3.2 255.255.255.0
tag-switching ip
ip address 192.168.4.1 255.255.255.0
tag-switching ip
router rip
version 2
network 3.0.0.0
network 192.168.3.0
network 192.168.4.0
no auto-summary
ip classless
ip http server
End
ROUTER PE02:
hostname PE02
ip cef
no ip domain lookup
ip vrf A2
rd 1:100
ip vrf B2
rd 1:200
interface Loopback0
ip address 2.2.2.2 255.255.255.0
ip address 192.168.4.2 255.255.255.0
tag-switching ip
interface Serial0/0
ip vrf forwarding A2
ip address 192.168.5.1 255.255.255.0
clock rate 64000
ip vrf forwarding B2
ip address 192.168.6.1 255.255.255.0
duplex auto
speed auto
router eigrp 100
auto-summary
address-family ipv4 vrf B2
redistribute bgp 1 metric 1000 100 100 100 100
network 192.168.6.0
auto-summary
autonomous-system 40
exit-address-family
address-family ipv4 vrf A2
network 192.168.5.0
auto-summary
autonomous-system 30
exit-address-family
router rip
version 2
network 2.0.0.0
network 192.168.4.0
no auto-summary
router bgp 1
no synchronization
neighbor 1.1.1.1 remote-as 1
neighbor 1.1.1.1 update-source Loopback0
no auto-summary
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 send-community extended
exit-address-family
redistribute eigrp 40
no auto-summary
no synchronization
exit-address-family
redistribute eigrp 30
no auto-summary
no synchronization
exit-address-family
ip classless
ip http server
End
ROUTER A2:
hostname A2
ip cef
no ip domain lookup
ip audit po max-events 100
interface Loopback0
ip address 30.30.30.30 255.255.255.0
interface Serial0/0
ip address 192.168.5.2 255.255.255.0
clock rate 2000000
router eigrp 30
network 30.0.0.0
network 192.168.5.0
no auto-summary
ip classless
ip http server
End
ROUTER B2:
hostname B2
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
interface Loopback0
ip address 40.40.40.40 255.255.255.0
ip address 192.168.6.2 255.255.255.0
duplex auto
speed auto
router eigrp 40
network 40.0.0.0
network 192.168.6.0
no auto-summary
ip classless
ip http server
End
3.Kiểm tra hoạt động:
·Đối với MPLS Domain :
i.Kiểm tra bảng định tuyến :
Trên PE01
PE01#show ip route
1.0.0.0/24 is subnetted, 1 subnets
C 1.1.1.0 is directly connected, Loopback0
2.0.0.0/24 is subnetted, 1 subnets
R 2.2.2.0 [120/2] via 192.168.3.2, 00:00:12, FastEthernet0/1
3.0.0.0/24 is subnetted, 1 subnets
R 3.3.3.0 [120/1] via 192.168.3.2, 00:00:12, FastEthernet0/1
R 192.168.4.0/24 [120/1] via 192.168.3.2, 00:00:12, FastEthernet0/1
C 192.168.3.0/24 is directly connected, FastEthernet0/1
Trên P
P#show ip route
R 1.1.1.0 [120/1] via 192.168.3.1, 00:00:07, FastEthernet0/0
R 2.2.2.0 [120/1] via 192.168.4.2, 00:00:11, FastEthernet0/1
C 3.3.3.0 is directly connected, Loopback0
C 192.168.4.0/24 is directly connected, FastEthernet0/1
C 192.168.3.0/24 is directly connected, FastEthernet0/0
Trên PE02
PE02#show ip route
R 1.1.1.0 [120/2] via 192.168.4.1, 00:00:27, FastEthernet0/0
C 2.2.2.0 is directly connected, Loopback0
R 3.3.3.0 [120/1] via 192.168.4.1, 00:00:27, FastEthernet0/0
C 192.168.4.0/24 is directly connected, FastEthernet0/0
R 192.168.3.0/24 [120/1] via 192.168.4.1, 00:00:27, FastEthernet0/0
Kết luận : Định tuyến nội giữa MPLS Domain đã thông, từ đó cấu hình MPLS
ii.Kiểm tra LFIP table
Trên PE01
PE01#show mpls forwarding-table
Local Outgoing Prefix Bytes tag Outgoing Next Hop
tag tag or VC or Tunnel Id switched interface
16 16 2.2.2.0/24 0 Fa0/1 192.168.3.2
17 Pop tag 3.3.3.0/24 0 Fa0/1 192.168.3.2
18 Pop tag 192.168.4.0/24 0 Fa0/1 192.168.3.2
Trên P
P#show mpls forwarding-table
16 Pop tag 2.2.2.0/24 3375 Fa0/1 192.168.4.2
17 Pop tag 1.1.1.0/24 5007 Fa0/0 192.168.3.1
Trên PE02
PE02#show mpls forwarding-table
16 Pop tag 3.3.3.0/24 0 Fa0/0 192.168.4.1
17 Pop tag 192.168.3.0/24 0 Fa0/0 192.168.4.1
18 17 1.1.1.0/24 0 Fa0/0 192.168.4.1
iii.Cấu hình BGP trên PE01 và PE02
Trên PE01
PE01#show ip bgp summary
BGP router identifier 1.1.1.1, local AS number 1
BGP table version is 1, main routing table version 1
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
2.2.2.2 4 1 55 54 1 0 0 00:43:36 0
Trên PE02
PE02#show ip bgp summary
BGP router identifier 2.2.2.2, local AS number 1
1.1.1.1 4 1 55 56 1 0 0 00:44:24 0
- Kiểm tra vrf routing table của A1,A2,B1,B2 trên PE01 và PE02
Trên PE01:
PE01#show ip route vrf A1
Routing Table: A1
B 192.168.5.0/24 [200/0] via 2.2.2.2, 00:45:07
D 10.10.10.0 [90/156160] via 192.168.1.1, 00:45:24, FastEthernet0/0
C 192.168.1.0/24 is directly connected, FastEthernet0/0
30.0.0.0/24 is subnetted, 1 subnets
B 30.30.30.0 [200/2297856] via 2.2.2.2, 00:45:07
PE01#show ip route vrf B1
Routing Table: B1
100.0.0.0/24 is subnetted, 1 subnets
D 100.100.100.0 [90/2172416] via 192.168.2.1, 00:44:46, Serial0/0
20.0.0.0/24 is subnetted, 1 subnets
D 20.20.20.0 [90/2297856] via 192.168.2.1, 00:44:46, Serial0/0
40.0.0.0/24 is subnetted, 1 subnets
B 40.40.40.0 [200/156160] via 2.2.2.2, 00:46:20
B 192.168.6.0/24 [200/0] via 2.2.2.2, 00:46:20
C 192.168.2.0/24 is directly connected, Serial0/0
Trên PE02:
PE02#show ip route vrf A2
Routing Table: A2
C 192.168.5.0/24 is directly connected, Serial0/0
B 10.10.10.0 [200/156160] via 1.1.1.1, 00:45:16
B 192.168.1.0/24 [200/0] via 1.1.1.1, 00:45:16
D 30.30.30.0 [90/2297856] via 192.168.5.2, 00:48:47, Serial0/0
PE02#show ip route vrf B2
Routing Table: B2
B 100.100.100.0 [200/2172416] via 1.1.1.1, 00:46:44
B 20.20.20.0 [200/2297856] via 1.1.1.1, 00:46:44
D 40.40.40.0 [90/156160] via 192.168.6.2, 00:49:30, FastEthernet0/1
C 192.168.6.0/24 is directly connected, FastEthernet0/1
B 192.168.2.0/24 [200/0] via 1.1.1.1, 00:45:59
- Kiểm tra thông tuyến:
A1#ping 30.30.30.30
Sending 5, 100-byte ICMP Echos to 30.30.30.30, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 196/236/300 ms
B1#ping 40.40.40.40
Sending 5, 100-byte ICMP Echos to 40.40.40.40, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 156/180/200 ms
- Kiểm tra bảng LFIP hoàn chỉnh trên mỗi Router PE01 và PE02:
19 Untagged 20.20.20.0/24[V] 0 Se0/0 point2point
20 Untagged 100.100.100.0/24[V] \
0 Se0/0 point2point
21 Untagged 10.10.10.0/24[V] 0 Fa0/0 192.168.1.1
22 Aggregate 192.168.1.0/24[V] 520
23 Aggregate 192.168.2.0/24[V] 520
19 Untagged 30.30.30.0/24[V] 520 Se0/0 point2point
20 Aggregate 192.168.5.0/24[V] 0
21 Untagged 40.40.40.0/24[V] 570 Fa0/1 192.168.6.2
22 Aggregate 192.168.6.0/24[V] 0
- Kiểm tra cơ chế chuyển mạch nhãn tại MPLS Domain
PE01#traceroute vrf A1 30.30.30.30
Tracing the route to 30.30.30.30
1 192.168.3.2 [MPLS: Labels 16/19 Exp 0] 160 msec 184 msec 144 msec
2 192.168.5.1 [MPLS: Label 19 Exp 0] 128 msec 60 msec 92 msec
3 192.168.5.2 176 msec * 216 msec
PE02#traceroute vrf B2 20.20.20.20
Tracing the route to 20.20.20.20
1 192.168.4.1 [MPLS: Labels 17/19 Exp 0] 176 msec 120 msec 156 msec
2 192.168.2.2 [MPLS: Label 19 Exp 0] 212 msec 64 msec 52 msec
3 192.168.2.1 92 msec * 160 msec
Chúc vui !!!
